It does sound like the brake fluid has been contaminated with a petroleum product. The definitive clue is when you get that caliper to lock up again, loosen the steel lines at the master cylinder. If you get a spurt of fluid from one of them, and the caliper releases, the contamination has caused the rubber lip seals in the master cylinder to grow past the fluid return ports and is blocking them. That's the same thing that happened to the bladder seal under the reservoir cap.
What looks like moisture under the cap is actually something else. Brake fluid loves to absorb water, and moisture out of the air. That's why it's important to keep containers of brake fluid sealed. Water won't pool or collect where it can be seen. It will mix with the brake fluid, then the only problems it causes is it leads to corrosion of metal parts over time, it speeds up the normal corrosion that builds up in the lower halves of the bores in the master cylinder, and it lowers the boiling point of the brake fluid from well over 400 degrees to closer to 212 degrees. That can cause one form of brake fade when the moisture boils and turns to vapor.
If contamination from a petroleum product such as power steering fluid, transmission fluid, engine oil, axle grease, or penetrating oil can be confirmed, the repair involves removing every part that contains rubber parts that contact the brake fluid, flushing and drying the steel lines, then installing new parts. That includes the master cylinder, the new cap seal, calipers, wheel cylinders, combination valve under or near the master cylinder, and all of the rubber flex hoses including the new one that was just replaced. Due to the wide range of loading variables, most trucks and minivans also have a rear height-sensing proportioning valve. Those have rubber o-rings, so they also must be replaced. If your vehicle has anti-lock brakes, the hydraulic controller must be replaced. If it does not have ABS, the combination valve is the junction block you mentioned. It sits on the frame rail under or near the master cylinder with the two steel lines running to it, and three leaving to go to the wheels. That valve is usually not used when the vehicle has ABS. If any part with a rubber part in it is not replaced, the contamination will leach out of it and recontaminate the new fluid and the new parts. This repair is expensive enough, but it gets a lot worse when we try to save a few dollars by not replacing all the parts at once.
The good news is most of the parts cost considerably less than they did 30 years ago. As far back as the 1980s, it was standard practice to rebuild calipers and wheel cylinders as part of a standard brake job, but today it's a much better value to buy professionally rebuilt assemblies with a warranty. Calipers in the '80s cost over $100.00. Pistons ran around $20.00 except for GM rear pistons for rear calipers. Those cost well over $100.00 each and were really miserable to bleed. Today rebuilt calipers run around $30.00 for most trucks.
Wheel cylinder rebuild kits are available, but they're not a good value unless that's all that is available. These are somewhat universal, so finding new ones isn't difficult, and they're pretty inexpensive. We can only buy new ones. There's no point in a company rebuilding old ones. In this case, you need to replace them anyway because they're made of cast iron. That's porous and will hold the contamination, then release it into the new brake fluid. You also get a new bleeder screw that's guaranteed to not be rusted tight or rounded off.
It's a good idea to pop one old wheel cylinder apart to read the size molded onto the inside of one of the lip seals. It's common to find three or four sizes are listed for one model. The difference has to do with the weight distribution due to optional equipment, and wheel base. The correct size is a design factor. It's important to install the same diameter wheel cylinders to maintain the front-to-rear brake balance.
You do not need to replace the power booster, as some people think. They do have rubber diaphragms inside them, but no brake fluid contacts them.
Let me know how this progresses.
May 12, 2023 at 5:24 PM
