Passenger door lock is stuck
1993 DODGE RAMCHARGER
241,000 MILES
HEYMOMDONTDOTHAT
My 93 Ramcharger has power locks which my mother insists on using manually. Her lock always gets stuck when she does that. Usually I'm able to get it to work by getting out and jiggling the key about inside the lock. I can feel something resisting, then it lets go and works properly until she pulls the lock up manually again, which she did today. Now the lock is stuck somewhere between locked and unlocked, and the door won't open from the outside or inside. The driver's side works fine. Any suggestions as to what the problem might be and how to fix it? Thanks.
Apr 24, 2013 at 5:18 PM
the actuator has failed. you will have to play with it till you get it to release and open. then you need to replace it before closing
Apr 24, 2013 at 5:26 PM
HEYMOMDONTDOTHAT
Thank you!
Apr 24, 2013 at 6:11 PM
