Sure, connect the light green to the black wire of the of the door ajar switch in the door jamb of the passenger door. You may need to remove the switch, which means removing the door panel to get to the wiring. here is what the switch looks like with a generic guide to help you remove the door panel:
https://www.2carpros.com/articles/door-panel-removal
Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Aug 3, 2022 at 4:11 PM
