Does the light turn on and not flash or does nothing happen? The design on this vehicle is somewhat complex. It doesn't use a traditional flasher. Instead, there is a front control module and rear control module.
Let me know that. Also, if nothing even turns on, check fuse 10 in the under hood fuse box first. Next, I made a quick copy of the two control modules I mentioned just so you can see how they play into the system.
Let me know exactly what is happening.
Jan 28, 2020 at 6:47 PM
