After about 10 minutes of driving my passenger airbag light turns on
2006 DODGE CHALLENGER
120,000 MILES
STARLORD1976
  • 173 POSTS
And when I turn car off and back on it stays off at first until about another 10 minutes.
Oct 27, 2020 at 11:47 AM
Good afternoon,
There is a code set in the system for the failure. It sounds like the seat sensor but needs to be confirmed.
You need to get the code checked. A parts store can read it for free for you. Once I know the code, I can help narrow the area of failure.
The seat weight sensors (4) are strain gauge-type units. The electronic elements of the sensor are encased in a potting material within the molded plastic sensor housing. Four sensors (4) are used in the Occupant Classification System (OCS). A sensor is located at each corner of the passenger side front seat.
The strain gauge for each sensor is secured by three screws and nuts (2) between the seat cushion frame and the seat adjusters (3). A molded connector receptacle (1) integral to each sensor housing is connected to the vehicle electrical system through a dedicated connector and take out of the passenger seat wire harness beneath the seat cushion frame.
The seat weight sensors cannot be adjusted or repaired and, if faulty or damaged, the entire sensor must be replaced.
WARNING:
The seat weight sensor is a sensitive, calibrated unit and must be handled carefully. Do not drop or handle roughly. If dropped or damaged, replace with another sensor. Failure to do so may result occupant injury or death.
the front passenger seat must be handled carefully as well. When removing the seat, be careful when setting on floor not to drop. If dropped, the sensor may be inoperative, could result in occupant injury, or possibly death.
when the seat is on the floor, no one should sit in the front passenger seat. This uneven force may damage the sensing ability of the seat weight sensors. If sat on and damaged, the sensor may inoperative, could result in occupant injury, or possibly death.
OPERATION
The seat weight sensor units are designed to sense the relative weight of a load applied to the passenger side front seat, which provides a logic input to the microprocessor of the Occupant Classification Module (OCM). When a load is applied to the seat, the strain gauge of each sensor is flexed causing a change of electrical resistance through the strain gauge. These changes in resistance are measured by the sensor and the internal sensor circuitry changes the sensor output voltage.
Each weight sensor receives a nominal five volts and a ground through parallel hard wired circuits from the OCM. The OCM then monitors the output voltage of each sensor on dedicated hard wired data communication circuits. The hard wired circuits between the sensors and the OCM may be diagnosed and tested using conventional diagnostic tools and procedures. However, the most reliable, efficient, and accurate means to diagnose the seat weight sensor inputs to the OCM, and the electronic message communication between the OCM and the Occupant Restraint Controller (ORC) requires the use of a diagnostic scan tool. Refer to the appropriate diagnostic information.
Oct 27, 2020 at 1:47 PM
Often times, it is related to a sensor in the seat that senses pressure. However, can you tell me the model? The Challenger wasn't offered in 2006.
If you meant a Charger, here are the directions for testing the seat weight sensor. It's a bit extensive and requires some testing. Let me know if I got the correct vehicle and if it is something you can do. It does require special tooling.
As a test only, attach the seat belt so the vehicle and see if it causes the light (SRS) to turn off. Do this once the light turns on.
The attached pics correlate with the directions.
_____________________
2006 Dodge Charger V6-3.5L VIN G
Diagnosis and Checkout Procedure For Seat Weight Sensors
Vehicle Restraints and Safety Systems Testing and Inspection Symptom Related Diagnostic Procedures Diagnosis By Symptom Diagnosis and Checkout Procedure For Seat Weight Sensors
DIAGNOSIS AND CHECKOUT PROCEDURE FOR SEAT WEIGHT SENSORS
Diagnosis And Checkout Procedure For Seat Weight Sensors
pic 1
1. VERIFY COMPLAINT
Turn the ignition off.
Move the front passenger seat to the full rear position. Verify that the seat is empty, the seat back is in the normal upright position, and that the seat is not interfering with any interior components.
Verify that all related connectors are properly seated and locked.
Turn the ignition on.
With the scan tool in OCM, select Data Display and note the Passenger Seat Weight Sensor voltage for all four sensors (Left Front, Right Front, Left Rear and Right Rear).
Move the front passenger seat to the mid track position.
Using the scan tool, note the Passenger Seat Weight Sensor voltage for all four sensors.
Move the front passenger seat to the full forward position.
Using the scan tool, note the Passenger Seat Weight Sensor voltage for all four sensors. The voltage should be from 1.4 to 3.6 volts for each sensor in each position (full rear, mid track, and full forward).
Q: Is any sensor's voltage reading out of the acceptable range in any position?
YES: Go To 2
NO: Perform test B1BA7 Occupant Classification System Verification Required. See: A L L Diagnostic Trouble Codes ( DTC ) > B Code Charts > B1BA7 If the test passes, the seat weight sensing system is working properly. Return to the procedure that directed you to this procedure.
2. CHECKING FOR BENT FLOOR PAN
Loosen all of the mounting screws retaining the front passenger seat to the vehicle crossmembers, but do not remove them. Verify that the seat is loose and that no binding exists between the seat and the crossmembers.
Move the front passenger seat to the full rear position and then to the full forward position.
Tighten all of the mounting screws to specification.
Using the scan tool, note the Passenger Seat Weight Sensor voltage for all four sensors. The voltage should be from 1.4 to 3.6 volts for each sensor in each position.
YES: Go To 3
NO: Perform test B1BA7 Occupant Classification System Verification Required. See: A L L Diagnostic Trouble Codes ( DTC ) > B Code Charts > B1BA7 If the test passes, the seat weight sensing system is working properly Return to the procedure that directed you to this procedure.
3. CHECKING SEAT TO RISER STRESS
Loosen all of the mounting screws retaining the front passenger seat track to the riser, but do not remove them.
Verify that the seat track is loose and that no binding exists between the seat track and the risers.
Using the scan tool, note the Passenger Seat Weight Sensor voltage for all four sensors. The voltage should be from 1.5 to 3.5 volts for each sensor.
Q: Is any sensor's voltage reading out of the acceptable range?
YES: Go To 4
NO: Visually inspect for damaged or bent risers and crossmembers. Also, verify that the riser holes line up with the seat mounts in the crossmembers.
If riser damage is apparent, replace the risers. Then, reinstall the Seat Weight Sensors, and Go To 6.
NOTE: Failure to follow test instructions or aborting the test will cause faults to set when performing the Occupant Classification Module System Verification Test. To prevent faults due to process errors: Verify That All Tests Steps That Led You Here Were Performed As Directed; Verify That The Ignition Is In Run; Wait 30 Seconds After Changing The Seat Weight Before Proceeding To Allow The System To Stabilize; Only Press Scan Tool Buttons When Directed To Do So; & Perform The Occupant Classification Module System Verification Test To Completion.
If crossmember or floor pan damage is present, repair or replace the components as necessary. Reinstall the seat in the vehicle. Turn the ignition on. With the scan tool in OCM, select More Options, select System Tests, and select Occupant Classification Module System Verification Test. Run the test by following the directions displayed on the scan tool. When the test is complete, Go To 1.
4. TEST SEAT FRAME
Remove the front passenger seat from the risers. Return the risers to their normal mounting position.
Using the scan tool, note the Passenger Seat Weight Sensor voltage for all four sensors. The voltage should be from 1.4 to 3.6 volts for each sensor.
YES: Go To 5
NO: Visually inspect for damaged or bent risers, a damaged or bent seat and seat structure, and damaged or bent seat tracks. Also, verify that the holes in the center of the sensors line up with the seat track holes and that the seat track position locating tabs are locked in the same parallel slots. If riser damage is apparent, replace the risers. Then, reinstall the Seat Weight Sensors, and Go To 6.
If seat or seat track damage is present, replace the components as necessary. Then, Go To 7
5. TEST SENSOR
Loosen the mounting screws of all of the Seat Weight Sensors, but do not remove them. Verify that the sensors are loose and that no binding exists between the sensors and the risers.
YES: Replace any Seat Weight Sensors that have an unacceptable voltage reading. Then, Go To 6.
NO: Replace the risers. Then, reinstall the Seat Weight Sensors, and Go To 6
6. CHECKING FOR IMPROPER SEAT WEIGHT SENSOR TORQUE
Tighten all of the Seat Weight Sensor mounting screws to specification.
YES: Loosen the mounting screws of all Seat Weight Sensors with an unacceptable voltage reading, and repeat Steps 5 and 6.
NO: Go To 7
7. TEST SEAT TRACKS
Mount the front passenger seat on the risers.
YES: Replace the seat track. Verify that no binding exists between the seat and risers. Then, repeat Steps 6 and 7.
NO:
Reinstall the seat in the vehicle. Turn the ignition on. With the scan tool in OCM, select More Options, select System Tests, and select Occupant Classification Module System Verification Test. Run the test by following the instructions displayed by the scan tool. When the test is complete, Go To 1
_____________________________
Note: There are a total of 4 weight sensors. One is in each corner. If you determine one is bad, I will need to know if the seat is power or manual control.
Oct 27, 2020 at 1:53 PM
