Unfortunately we don't have a diagram of the system like this that would assist in an issue like this. What I would suggest with that amount of fuel is lay on the ground next to the vehicle, not under it and have someone turn the key to the on position. You should see the general area that the fuel is coming from. Then after the fuel is not spraying or dripping any longer, start looking closer in that area. Clearly you don't want the fuel to spray on you so just wait until you can safely look closer. Then see if you can find the component.
The fact that the fuel filter was just changed, I suspect one of the lines on the filter is not fully hooked on.
Clearly we don't want to drive this vehicle until this is resolved. Let me know what you find or questions you have. Thanks
May 12, 2020 at 9:24 AM
