Parking/taillight fuse burns out
2003 PONTIAC VIBE
190,000 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
VMR
  • 4 POSTS
My son's car's parking/taillight/license plate lights are inoperable. The fuse on this circuit burns out as soon as the multi-function switch on the steering column is placed in park or headlight position. This problem seems identical to a December 2011 discussion on 2CARPROS where the technician recommended a signal tracer. I think this is the correct approach.
However, when piecing together the car's wiring diagrams there seems to be missing information. Between the "left of steering column behind storage compartment" connector and "right instrument panel junction block" connector it seems that there may be another connector and/or additional circuits not shown.
Can you please help with this?
Clarification on the car's wiring diagrams: I am referring to the three diagrams provided in the 2CARPROS response in December 2011. Sorry for not be clear about this.
Jan 4, 2018 at 7:36 AM
CARADIODOC
  • 34,306 POSTS
Here is an easier approach. A simple trick to finding a short is to replace the blown fuse with a pair of spade terminals, then use small jumper wires to connect them to a twelve volt light bulb. A brake light bulb works well. When the circuit is live and the short is present, the bulb will be full brightness and hot so be sure it is not laying on the carpet or against a plastic door panel. Now you can unplug electrical connectors and move things around to see what makes the short go away. When it does, the bulb will get dim or go out.
You are not likely to find the cause of the problem under the dash where everything is protected. Better suspects are crushed wires in the trunk, chewed-up trailer wiring harnesses, and problems in bulb sockets. I have also found a few pinched wires behind tail lamp assemblies after someone spliced in trailer wiring to those wires. Those do not show up right away. It takes some time for screw's threads to work their way through the wire's insulation and cause a short.
Jan 4, 2018 at 6:07 PM
VMR
  • 4 POSTS
Thanks! That is an excellent suggestion. I will be working on this car soon and will report back on how well this works and (hopefully) where the short was found.
Jan 5, 2018 at 7:05 AM
