I attached the entire wiring schematic below for the exterior lighting system. We simply need to determine where power is lost. Since none of the parking lights work, it is likely at the fuse box.
The first 4 pics below are the exterior wiring schematics for the exterior lights. I highlighted all wires related to the parking lights. The last 4 are power distribution schematics.
There are several possible issues, but again, since none of the lights work, it is at the fuse box or before it. I'm basing that on the different directions the wiring branches after the taillight relay, which we still need to locate.
First, if you look at pic 1, it shows a 10-amp tail lamp fuse. Check the fuse. Next, with the lights turned on, see if there is power to and from that fuse. Pic 9 below shows the fuse and its location. (Interior fuse panel).
Start with this. Also, I went through every schematic I could find although the info below shows a relay, nothing is found. There is a chance something is different based on the production date.
Check in the door frame (driver's) and see if you can locate the date of production and let me know what it is.
Take care and let me know about the fuse I mentioned.
See pics below.
Mar 22, 2022 at 7:45 PM
