Parking lights not shutting off
2003 MINI COOPER S
133,000 MILES • 1.6L • 4 CYL • TURBO • 2WD • MANUAL
CYNTHIACRESSEY
Yesterday water came in through my clogged sunroof. Now when I get out of car and turn lights off and take key out of it my parking lights stay on. I have tried to take battery cables off to reset. Now I am taking two fuses out under the hood so parking lights will go off so my battery does not drain.
Sep 9, 2018 at 4:29 AM
I would check fuse #40 and #5 which control the switch and general lighting module. Next I would unplug the headlight switch to see if they go out. Here is a guide to help you test the fuses and the fuse location as well as the running light wiring diagrams so you can see how the system works:
Check out the diagrams (below). Please let us know what you find.
Sep 10, 2018 at 12:47 PM
