This sounds like your vehicle might have a short to power in the parking lamp circuit. I need you you to take a voltage reading at pin # 2 and 6 in from the secondary junction block with the light switch off. I have included the exterior lighting wiring diagram and the location of the secondary junction block in the diagrams down below. I have also included a link below for you to go to if you are unfamiliar with how to use a multi-meter. You will need to use one to a voltage reading for tracking this short down.
Please go through these guides and get back to us with you get on the two voltage readings. We will go from there.
Thanks,
Alex
2CarPros
May 1, 2019 at 6:38 AM
