Take a look at the picture below. This is a view from the front, and you are going to be adjusting from the rear, but the idea is the same.
In order to make the shoes tighter, you need to make the adjuster longer. This means you need to loosen the adjuster nut by turning it to the left if you are looking at it straight on.
So, picture holding it in your hand and turning the nut to the left, then based on its orientation which way to do you have to turn it?
The way I look at it, you will have to push the adjuster down moving the flat head screwdriver from the top of the opening to bottom.
However, no matter way, you cannot over adjust these and have the adjuster come off. If you do, they will get too tight, and you will have to go the other way.
If you are loosening, then you simply reverse the direction.
Jun 14, 2022 at 11:09 AM
