Parking and Fog lights stay on?
2000 MERCEDES BENZ SLK230
79,000 MILES • 4 CYL • TURBO • 2WD • AUTOMATIC
LIGHT ON
After the car is turned off and locked the parking lights and fog lamps stay on until the battery drains. I know they are supposed to stay on for a couple of minutes and turn off automatically. But they stay on “forever now. Yes, the headlight switch is in the "off" position. And pushed “in" (i.E. Fog lamps OFF).
I did see you gave advice to check the PSE for wetness (Oct 2007). If it is so, then how to fix it? Replace the PSE? Please advice in more detail. Your advice is greatly appreciated.
May 27, 2016 at 4:08 PM
MHPAUTOS
  • 31,937 POSTS
In the context of a 2000 Mercedes-Benz SLK230 where the parking lights and fog lamps stay on even after the car is turned off and locked, the issue might be related to a malfunction in the PSE (Pneumatic System Equipment) module. The PSE module is responsible for controlling various functions in the vehicle, including the central locking system, windows, mirrors, and sometimes lighting.
Here's how you can troubleshoot and potentially fix the issue:
Inspect for Wetness: Water intrusion into the PSE module is a common issue in some Mercedes-Benz models, including the SLK230. Check the location of the PSE module (usually located in the trunk, under the carpet or in a compartment) for signs of moisture, corrosion, or water damage. If you find any, you'll need to address this issue first.
Drying and Cleaning: If you find water or moisture around the PSE module, remove it from its location and thoroughly dry it. You might also need to clean any corrosion or buildup caused by the moisture.
Inspect Wiring and Connections: Check the wiring and connections around the PSE module for any damage or loose connections. Make sure all connectors are securely attached and free from corrosion.
Check Fuses: Look for any blown fuses related to the lighting system. Sometimes a blown fuse can cause abnormal behavior in the electrical system.
Reset the PSE Module: Disconnect the vehicle's battery for a few minutes to reset the electronic modules. This might help clear any temporary glitches.
PSE Replacement: If the PSE module is damaged beyond repair or if water damage has caused irreversible issues, you might need to replace the PSE module. This could involve sourcing a new or used module that's compatible with your vehicle and installing it. If you're not familiar with automotive electronics, it's recommended to have a professional technician perform this replacement.
May 27, 2016 at 5:35 PM
