I have my battery going dead overnight. When I hook a meter in series it shows 3.35 draw. Removing fuses ,two circuits show a significant drop to .003 total draw with both fuses removed. One fuse is the cluster, the other is
SPDJB brake shift interlock. Is there a relay for the interlock I can check? Where is it located? I don’t see it labeled in with the fuse panel which has the 10 amp fuse in position 5 or power distribution panel
Is there a solenoid perhaps I’m missing and if so, can you tell me where it’s located? How do I troubleshoot what to check next?
Aug 6, 2025 at 1:43 AM
