Car failed to start, gas gauge on empty, airbag lights on, immobility service on message board. I went back with spare keys everything worked car started drove home. Next morning same thing. This time I drove it farther. Several time, about 4, during the trip gas gauge dropped to empty, airbag lights came on, same message came up. Car kept running so I kept driving and 2 to 3 seconds after it started it clears. Is this an anti theft mater. Key switch, PCM, BCM, could be involved however mechanic friend said similar problem turned out to be corroded relay near fans. Is there a PCM relay if so where is it.
Sep 6, 2019 at 6:34 PM
