Code p2767?
2005 DODGE MAGNUM
133,333 MILES • 5.7L • V8 • 2WD • AUTOMATIC
WILLIE HURLOCKER
  • 83 POSTS
I'm back! Hey Ken, well, it was driving fine went probably 35/40 miles in/out of traffic today. i changed the fluid/filter in the transmission fluid level is good. i didn't change all 16 quarts of fluid (you know not that in the torque conv). just from the pan. Then it's fine for this long. Do you think it's the turbine sensor or dirty fluid? also, could the play in the rearend yoke have something to do with it? If so, is there a way to tighten up the slack in the rearend?
Jul 14, 2023 at 8:39 PM
Hey Willie,
It sounds like the Input shaft or turbine shaft speed sensor is bad.
The error code P2767 in a 2005 Dodge Magnum corresponds to an issue with the Transmission Control Module (TCM).
Here is how to change the sensor it out (1). Be sure to clear the codes after the repair is complete. Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Jul 15, 2023 at 11:39 AM
WILLIE HURLOCKER
  • 83 POSTS
i have a nag 1 transmission. Isn't the sensor on the conductor plate inside the transmission?
Jul 15, 2023 at 11:50 AM
I double checked and this is where they say it is. Check out the images (below). Please let us know what happens.
Jul 16, 2023 at 9:56 AM
WILLIE HURLOCKER
  • 83 POSTS
this is the turbine speed sensor on a 722.6 transmission on the conductor plate!
Jul 16, 2023 at 10:53 AM
Maybe it is a mid-year change, I would inspect the transmission and if the sensor is not on the side of the transmission it is inside on the conductor plate. Please let us know what you find.
Jul 17, 2023 at 10:02 AM
WILLIE HURLOCKER
  • 83 POSTS
I've already changed out the conductor plate with the sensor on it. So far, it's doing okay. Kind of slow changing into 3rd hopefully it's just fluid level!
Jul 17, 2023 at 10:59 AM
Good job, it might take some time for the logic to relearn, just keep driving it it should be okay. Use 2CarPros anytime, we are here to help. Please tell a friend.
Jul 18, 2023 at 10:04 AM
WILLIE HURLOCKER
  • 83 POSTS
I've passed it on and I'm sure you'll be hearing from me again! This darn wagon is a money pit!
Jul 18, 2023 at 1:13 PM
