Good morning,
The 1201 is for the vehicle stability system. I attached some information for you below to read. You will need an advanced scan tool to monitor the system and see where the failure is located.
The 2757 is for the transmission. Did you ever change the fluid and filter in the transmission? A common issue is a dirty valve body from contaminated fluid.
https://www.2carpros.com/articles/automatic-transmission-problems
BRAKE CONTROL: VEHICLE STABILITY CONTROL SYSTEM: C1201/51: Engine Control System Malfunction
DTC C1201/51 - Engine Control System Malfunction
DESCRIPTION
If a malfunction in the engine control system is detected through the CAN, the operations of VSC and TRAC are prohibited by the fail-safe function. When the signals from the engine are input normally, the fail-safe is canceled and the DTC is stored.
INSPECTION PROCEDURE
NOTE: When replacing the VSC actuator assembly, perform zero point calibration (See: Antilock Brakes / Traction Control Systems > Programming and Relearning > Calibration).
PROCEDURE
1. CHECK DTC (FOR SFI SYSTEM)
(a)for 1GR-FE:
Clear the DTC (SFI system) (See: Computers and Control Systems > Reading and Clearing Diagnostic Trouble Codes > DTC Check / Clear).
for 2UZ-FE:
for 3UR-FE:
(b)for 1GR-FE:
Check the DTC (SFI system) (See: Computers and Control Systems > Reading and Clearing Diagnostic Trouble Codes > DTC Check / Clear).
for 2UZ-FE:
for 3UR-FE:
Result
D -- GO TO SFI SYSTEM
C -- GO TO SFI SYSTEM
B -- GO TO SFI SYSTEM
A -- USE SIMULATION METHOD TO CHECK
2757
MONITOR DESCRIPTION
Torque converter lock-up is controlled by the ECM based on the turbine (input) speed sensor NT, output speed sensor SP2, engine rpm, engine load, engine temperature, vehicle speed, transmission temperature, and gear selection. The ECM determines the lock-up status of the torque converter by comparing the engine rpm (NE) to the input turbine rpm (NT). The ECM calculates the actual transmission gear by comparing input turbine rpm (NT) to output shaft rpm (SP2). When conditions are appropriate, the ECM requests lock-up by applying control voltage to shift solenoid SLU. When SLU is turned ON, it applies pressure to the lock-up relay valve and locks the torque converter clutch.
If the ECM detects no lock-up after lock-up has been requested or if it detects lock-up when it is not requested, the ECM interprets this as a fault in the shift solenoid valve SLU or lock-up system performance.
The ECM will illuminate the MIL and store the DTC.
Example:
When one of the following conditions is met, the system determines that there is a malfunction.
There is a difference in rotation between the input side (engine speed) and output side (input turbine speed) of the torque converter when the ECM commands lock-up ON.
Engine speed is at least 70 rpm greater than input turbine speed.
There is no difference in rotation between the input side (engine speed) and output side (input turbine speed) of the torque converter when the ECM commands lock-up OFF.
The difference between engine speed and input turbine speed is less than 35 rpm.
May 3, 2020 at 6:11 AM
