Hello, my Sequoia (essentially a 5.7L Tundra) just had the trouble code P2446 pop up last night. The engine is still running just fine, so it does not seem to be in limp mode and no noticeable driving issues.
This seems to be a common part to go out on a Tundra, but I am not one to just replace automatically, so is there anything besides a bad valve that could cause the trouble code, and anything else that I can check first?
Also, I assume/hope that even if the valve set needs to be replaced, then I can possibly avoid replacing the air pumps as well, but I wanted to get your input on that as well.
Thank you!
Thank you!
Jul 9, 2025 at 9:25 AM
