Engine started running rough very little throttle response. lightning bolt came on plus p0171 code, I assume limp mode. replaced mass airflow by air cleaner then set a new code p2432 symptoms never changed checked relay, airflow sensor and air pump everything checks out good all wiring is good now its setting a p050b code as well I assume in relation .
there is no power after relay going to pump after start up so air pump is not coming on but there is power going to relay.
Feb 9, 2020 at 2:13 PM
