I didn't realize you had a catalytic converter code. I thought the P2227 was the code causing a problem. If you have resolved that issue, that is good news.
As far as the P0420, that indicates the catalytic converter is operating below threshold. In most cases, the converter needs to be replaced. To check it, you can use an infrared thermometer to see if it is functioning.
With the engine running and at operating temperature, check the inlet temp of the converter. Then, check the outlet temp. The outlet temperature should be hotter. If it isn't, then the oxygen sensors can't do their job which is likely causing an air fuel mixture issue. Here are two links, one explains the result of a faulty converter, and the other link explains how to test one:
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
Let me know if that helps or if you have other questions.
May 21, 2024 at 6:44 PM
