Code P2127?
2009 CHEVROLET IMPALA
100,000 MILES • 3.5L • 5 CYL • 2WD • AUTOMATIC
WILLIEJAQUAN
I keep getting code P2127: Throttle/Pedal Position Sensor/Switch “E” Circuit Low. This started off as an "engine power reduced" message maybe every 4-6 months but it always went away after restarting the car, until it didn't.
At this point I've cleaned inside the throttle body, and I've gotten a new gas pedal. Nothing is helping.
At the moment I'm not even getting a code on my reader.
I have an idea to simply unplug the 2nd air check valve sensor, but I can't find it.
Can anyone help me find the sensor or should I just replace the throttle body?
Any suggestions are welcomed.
Sep 6, 2023 at 7:07 AM
If you have replaced the accelerator pedal with sensor then I would replace the throttle body, cleaning it will not help. Here is how to change the throttle body out correctly and I have included the accelerator pedal as well to make sure we are on the same page. Check out the images (below). Please let us know how it goes.
Sep 6, 2023 at 12:43 PM
