The code may be a result of the intake, but it is not likely. The code is specific to the intake runner sensor. An intake runner is a component of the intake manifold.
The intake manifold has a series of passages or "runners" that distribute air from the throttle body to each of the engine's cylinders. These runners are designed to optimize the flow of air into the cylinders.
The intake runner sensor is likely the cause in this case simply because you indicated it is running properly. If there was an issue with one of the runners, there would be drivability issues. See pic 1 below for sensor location.
Additionally, I attached the diagnostics for you related to the code/sensor. Take a look through them and let me know if you are comfortable performing them.
See pics below.
Oct 31, 2023 at 7:39 PM
