Blinking d light, code P1888
2005 HONDA JAZZ
118,000 MILES • 1.3L • 4 CYL • 2WD • AUTOMATIC
JAY AR SULO
  • 4 POSTS
I have the car listed above CVT idsi. blinking d light.p1888 dtc appeared.reverse is okay but drive is failing. i already changed CVT speed sensor. checked wiring and harness seems fine and with continuity. what could be the problem? please help me.thank you in advance.
May 18, 2021 at 7:46 AM
Let's check the fluid condition to see if the transmission is burnt which is common in these cars. Lets try to do a fluid service. here is a guide to help you step by step with instructions in the diagrams below to show you how on your car:
May 19, 2021 at 11:57 AM
JAY AR SULO
  • 4 POSTS
It seems like my CVT fluid is fine, the color is okay and no burnt smell.One more thing I noticed is that everytime I try to test drive the vehicle in cold condition the drive mode works but after approximately 1 0minutes when the vehicle turns to optimal temperature the problem occurs again.
May 19, 2021 at 2:59 PM
NICKOLAOSF
  • 69 POSTS
Hi Jay Ar Sulo,
It sounds like transmission issues and should proceed to diagnosis.
here are a chart below to proceed. for the that code.
also if you have a tester to check transmission temperature that would help as well.
cheers, Nick
May 19, 2021 at 10:59 PM
JAY AR SULO
  • 4 POSTS
Hello sir. I noticed on the diagram you send to me is for Honda Civic, my car is Honda Jazz. Do you think they have just the same diagram?
May 20, 2021 at 5:15 AM
NICKOLAOSF
  • 69 POSTS
yes the procedure is the same, my program does not show Jazz, use that for now
you can test the speed sensor see chart below.
May 20, 2021 at 5:20 AM
