P1786 Code/ Car in EP mode?
2008 MINI COOPER
138,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
BRIAN STEWART
I recently took my vehicle listed above convertible to an import mechanic shop and they used a diagnostic code reader that gave the code P1786/ Transmission Ratio Plausibility. I was told, "There's an internal excessive ratio error, we will need to replace the transmission." I need help understanding what that means and if it means there is no choice but to replace the transmission. They want to charge $7,000 to replace it.
Jan 21, 2024 at 1:21 PM
BORIS K
  • 836 POSTS
Your vehicle is fitted with the 6-speed automatic Aisin TF60SN transmission.
P1786 - ratio plausibility
This fault code could have several different causes.
The basic fault means that the engine speed and transmission speed, actual/desired, are outside of specific parameters.
This could be caused a gear slipping inside the transmission, an issue inside the valve body (hydraulic controller inside the transmission) or possible speed sensor issues external of the transmission.
See a video regarding valve body issues:
https://youtu.be/b_rDACqbsDw?si=W09Yh4Y2KmCfVV4h#
and
https://youtu.be/s5CNDQZmKlg?si=TGA2fLZuUif8hxt8
I would suggest getting a second opinion.
Perhaps try:
https://www.transmissionsolympia.com/mini-cooper-tf60sn-transmission-repair/
They appear to specialize in transmission repair for your vehicle.
Cheers, Boris
Jan 22, 2024 at 4:03 AM
