I suspect that either there is an open circuit or the bypass regulator is bad. The idea that he checked the connections for water and breaks should have shown an open, but he could have missed it. Since it works for some time and then fails, I have a feeling the bypass regulator is bad, but testing will prove that.
______________________________________
Here are the diagnostics for troubleshooting the problem. However, you need a manufacturer-specific scan tool to do it (VAG). I don't know if your mechanic has one. There are no options for other types of scan tools or programs.
2003 Volkswagen Golf (1J1) L4-1.9L DSL Turbo (ALH)
With Manufacturer's Scan Tool
Vehicle Powertrain Management Computers and Control Systems Testing and Inspection Scan Tool Testing and Procedures Output Diagnostic Test Mode (DTM) With Manufacturer's Scan Tool
WITH MANUFACTURER'S SCAN TOOL
Function 03: Output Diagnostic Test Mode (DTM)
Performing Output Diagnostic Test Mode
Special tools and equipment
- Scan Tool (ST) VAG 1551 or VAG 1552 with cable VAG 1551/3
Test conditions
pic 1
- Main fuses OK.
pic 2
- The fuses must be OK.
- The battery voltage must be at least 11.5 V.
- All electrical consumers, e.g. lights and rear window heating must be switched off.
Prerequisites (with air conditioning)
- Vehicle at room temperature, warmer than + 15 degree C (59 degree F)
- A/C on
- Lowest temperature setting and highest blower speed
The Output diagnostic test mode activates the following components in the following sequence:
1. Cold Start Injector -N108-
2. EGR Vacuum Regulator Solenoid Valve -N18-
3. Air Conditioning compressor interrupt
4. Fuel Cut-off Valve -N109-
5. Wastegate Bypass Regulator Valve -N75- for boost control
6. Glow Plug Relay -J52-
7. Glow Plug Indicator Lamp -K29-
8. Relay -J359- preheat coolant, low heat output (man. trans. only)
9. Relay -J360- preheat coolant, high heat output (man. trans. only)
10. Malfunction Indicator Lamp (MIL) -K82-, Exhaust Warning Lamp -K83- (MIL is shown in the 1551 display, however; -K83- Exhaust Warning Lamp is the actual component being tested)
NOTE:
- Activation of individual control elements is limited to 30 seconds. but can be stopped at any time by pressing button.
- Ignition must be switched off before repeating Output Diagnostic Test Mode.
Work sequence
- Connect Scan Tool (ST) VAG 1551/(VAG 1552). With engine idling select Engine Control Module (ECM) with "Address word" 01 (Connecting Scan Tool (ST) and selecting ECM. See: Computers and Control Systems > Scan Tool Testing and Procedures > Connecting VAG 1551 Scan Tool)
Indicated on display:
Rapid data transfer HELP
Select function XX
- Operate Scan Tool (ST) and advance through program sequence by following display.
- Press buttons -0- and -3- for "Output Diagnostic Test Mode" (DTM).
03 Output Diagnostic Test Mode (DTM)
Activating Cold Start Injector -N108-:
- Press -Q- button to enter input.
Final control diagnosis ->
Activating the valve, influences the noise of combustion considerably (pre-ignition).
If no changes in the combustion noises are heard:
- Check injection adjuster control range. See: Computers and Control Systems > Component Tests and General Diagnostics > Diesel Injection Timing Control Range, Checking
Activating EGR Vacuum Regulator Solenoid valve -N18-:
- Press -> button.
Exhaust Gas Regulator Valve -N18
Valve must click.
NOTE: It is difficult to hear the valve click due to engine noise. Determine valve operation by feel (touch).
Valve does not click:
- Check EGR Vacuum Regulator Solenoid Valve -N18-
Activating air conditioning compressor interrupt:
- Press -> button.
Output Diagnostic Test Mode ->
A/C Compressor interrupt
Air conditioner compressor switch-off is checked.
The test step is also called on vehicles without air conditioner system.
A/C compressor must stop within 5 seconds (visual check) then start approx. every 5 seconds and then stop.
If A/C compressor does not switch off:
- Check signals from/to air conditioning system. See: A/C Signal > Component Tests and General Diagnostics > A/C System Signals, Checking
Activating Fuel Cut-off Valve -N109-:
- Press -> button.
Output Diagnostic Test Mode Fuel cut-off valve -N109
The engine must stop.
If engine does not stop:
- Switch off ignition.
- Unscrew fuel shut-off valve and remove any metal particles or dirt, item 4 .
- Repeat Output Diagnostic Test Mode, if engine will not stop replace Fuel Cut-off Valve -N109-.
- Continue Output Diagnostic Test Mode with engine stopped and ignition switched on.
Activating Wastegate Bypass Regulator valve -N75-:
- Press -> button.
The solenoid valve must click.
NOTE: The clicking operation of the valve is difficult to hear and is therefore best checked by touch.
If the solenoid valve does not operate:
- Check charge pressure control solenoid valve -N75-:
Activate Glow Plug Relay -J52-:
- Press -> button.
Glow plug relay -J52
Vehicles through MY > 2001
Relay must click.
Switching relay on and off can also be observed by the brightening and
dimming of the interior light as a result of glow plug power consumption.
If relay does not click:
- Check glow plug relay:
Vehicles from MY 2002>
NOTE: This engine has a Glow Period Control Module - J370- installed. It is not possible to optically and acoustically check the activation, this is only possible by connecting a current pick-up clamp to the glow plug wiring. See: Glow Plug > Component Tests and General Diagnostics > Glow Plugs, Checking
Continued for all vehicles
Activate glow period warning lamp (K29):
- Press -> button.
Glow Plug Indicator Light -K29- does not blink:
Glow Plug Indicator Light -K29- must blink.
- Check Glow Plug Indicator Lamp -K29-:
Activating Relay for low heat output -J359- (only on vehicles with manual transmission):
- Press -> button.
Low heater output relay -J359
The relay must click.
If the relay does not click:
- Check low heat output relay:
Activating Relay for high heat output -J360- (vehicles with manual transmission):
- Press -> button.
High heater output relay -J360
- Check relay for preheating coolant, high heat output -J360-.
Activating Malfunction Indicator Lamp (MIL) and Switch -K82-:
- Press -> button.
Malfunction Indicator Lamp (MIL) Indicated on display:
MIL must flash.
MIL does not flash:
- Check Malfunction Indicator Lamp (MIL) and Switch -K82-:
- Press -> button.
Select function XX
- Press buttons -0- and -6- for "End output" and confirm with -Q- button.
Note: The directions check several different components, the wastegate bypass regulator is one of the things.
Oct 25, 2020 at 6:18 PM
