Good morning,
Is the ABS light on as well as the check engine light? If it is not, then you need a ECM. The code is for both systems.
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
P1502-VEHICLE SPEED SENSOR 1/2 CORRELATION - NON DRIVE WHEELS
P1502 - Vehicle Speed Sensor 1/2 Correlation - Non Drive Wheels
WHEN MONITORED
Ignition on and vehicle moving. Cruise is learned and customer is trying to use the Cruise.
SET CONDITION
The PCM recognizes rear wheel speed is greater than front wheel speed.
POSSIBLE CAUSES
Vehicle speed signal circuits shorted to voltage
Vehicle speed signal circuits shorted to ground
Tire circumference
PCM
Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding.
Diagnostic Test
1. ACTIVE DTC
Ignition on, engine not running.
With a scan tool, read DTCs.
Q: Is the DTC active at this time?
YES: Go To 2
NO: Refer to the INTERMITTENT CONDITION Diagnostic Procedure. Perform the POWERTRAIN VERIFICATION TEST. See: A L L Diagnostic Trouble Codes ( DTC ) > Verification Tests > Powertrain Verification Test
2. VISUAL INSPECTION
NOTE: This code can set due to tire circumference differences and from the front or rear wheels being on a slippery surface while the opposite tires are not.
This code may also set on a hard acceleration on loose gravel or during other off road driving conditions.
Check tire pressure of all the tires.
Check tire wear on all the tires.
Ask the customer what the road and driving conditions were like when the fault set.
Q: Were any problems found?
YES: Repair as necessary. If the code set during a front OR rear wheel spin condition, no repair is necessary. Perform the POWERTRAIN VERIFICATION TEST. See: A L L Diagnostic Trouble Codes ( DTC ) > Verification Tests > Powertrain Verification Test
NO: Go To 3
3. VSS SIGNAL CIRCUITS SHORTED TO VOLTAGE
CAUTION:
Certain ABS systems rely on having the Powertrain Control Module (PCM) broadcast the Vehicle Identification Number (VIN) over the bus network. To prevent problems of DTCs and other items related to the VIN broadcast, it is recommend that you disconnect the ABS CAB (controller) temporarily when replacing the PCM. Once the PCM is replaced, write the VIN to the PCM using the DRB scan tool. This is done from the engine main menu. Arrow over to the second page to "1. Miscellaneous". Select "Check VIN" from the choices. Make sure it has the correct VIN entered before continuing. When the VIN is complete, turn off the ignition key and reconnect the ABS module connector. This will prevent the setting of DTCs and other items associated with the lack of a VIN detected when you turn the key ON after replacing the PCM.
Use the DRB scan tool to reprogram the new PCM with the vehicles original identification number (VIN) and the vehicles original mileage. If this step is not done, a Diagnostic Trouble Code (DTC) may be set.
REMOVAL
The PCM (1) is located in the engine compartment attached to the dash panel (3).
To avoid possible voltage spike damage to the PCM, ignition key must be off, and negative battery cable must be disconnected before unplugging PCM connectors.
1. Disconnect negative battery cable at battery.
2. Remove cover over electrical connectors. Cover snaps onto PCM.
3. Carefully unplug the three 32-way connectors (four 38-way connectors if equipped with NGC) from PCM (1).
4. Remove three PCM mounting bolts (3) and remove PCM from vehicle.
Jan 5, 2021 at 5:13 AM
