Previously I never had any engine related issues with my car listed above 1.4vvti, but recently my oil light came up, so I took it for oil change. Even after the oil change the light came on so we started to investigate the cause. It turned out that the oil pan sub-assembly was full of dirt, it was black and felt like sand, but I am sure it was burnt oil. It was all around, even on the camshafts so we decided to do a full cleaning as well as to change the chain, gear assembly (smart wheel), sprocket, tensioner, dampers. Also, the oil and water pump has been replaced. Compression is good, and the engine runs nice when it's cold.
Once warmed up (after driving around 12 kms) the check engine light comes up and I am getting P1345 error code.
I've seen in an earlier post that someone was recommending changing the camshaft timing oil control valve, so I bought a new one, we also cleaned the small metal oil filter below the valve and just to be on the safe side we also replaced the crank position sensor.
Unfortunately, the check engine light still comes up after around 12 kms (when the engine warms up) and the error code is still P1345.
When the engine is cold it starts immediately, but once I stop after 12 kms (when the check engine light comes up) and try to restart, it wouldn't start without pushing the acceleration pedal. After the light coming up I can still drive further and I cannot hear any change in the engine sound, but this error code bothers me.
Certainly, there's new oil in the engine.
I don't know what else could be the problem, so I am open to any ideas, comments, especially from those members who had the same issue.
The only thing that comes to my mind is a broken or weak wire that could change its resistance after the engine comes to its operating temperature.
I would really appreciate any help as I am quite hopeless at the moment.
Thanks in advance!
Thanks in advance!
Apr 14, 2023 at 12:47 PM
