Hi Danny, this car is with my son at college, so did not get to full troubleshooting until today. Looks like everything is good with the ECM. All measurements were taken on the Ignitor connector:
* While cranking IGT1, 2, 3 readings were jumping around. The highest reading I saw was 1.25V on a meter that updated about 2-3 times a second at terminal 5, 6 and 7. All three circuits behaved the same way in readout.
* IGF at terminal 4 was 5V and steady.
* I got battery voltage at terminal 2
* Also had battery voltage at terminals 1, 9 and 10
I explained on last update that something was draining the battery while the ignition switch was on, actually it is draining while the switch is off and key removed. Measured a steady 1A leak to ground. So the battery was very weak when I was seeing voltage drops with the ignition on last time. This time the battery was charged up, and I measured the leakage with everything off.
Cleared the p1300 code, and tried to start it several times. Is does start, but stops as soon as the key is taken off crank position. The p1300 came back, so it locks in immediately.
Not sure what the options are to test the ignitor. Are there any?
And, I got an electrical short somewhere, maybe independent of the ignition system issue??
*Maybe I start with the 15A fuse between battery and ignition switch to see if current draw goes away-that would indicate ignitions switch.
*Then pull 40A fuse to the starter relay to see if it goes away-that would indicate starter relay
I am also temped to buy an ignitor on eBay to see if the code goes away.
Any other suggestions are welcome for sure.
Thanks
Tim
Oct 24, 2019 at 6:22 PM
