Truck started running real rough suddenly. Reader showed I had a P0304 code. I checked #4 plug and had a hole in the rubber that goes over the spark plug. Only 31,000 miles on a rebuilt engine with new plugs and wires, so I replaced all wires and tubes (best grade belden) down from the coils, not the plugs or coils though. Now it won't run and I get the 1300 code (coil). Should I just replace all coils since I don't know if they were replaced with rebuild or could it be something else? I'm not sure how to check each individual coil. Thanks in advance.
Dec 18, 2019 at 4:09 PM
