Good morning,
Did the car overheat? It is a signal for the cylinder head over temperature. This will shut the car off as protection to potential engine damage.
Diagnostic Trouble Code (DTC) Charts and Descriptions
Note:Refer to the applicable diagnostic/repair information to diagnose the body and chassis DTCs.
Note:An X equals any number 0 through 9 or the letter A through F.
P1299 - Cylinder Head Over Temperature Protection Active
Below is a TSB that covers several issues including the 1299 code.
OVERVIEW
A software error exists in the Powertrain Control Module (PCM) that allows Anti-lock Brake System (ABS) and Output Shaft Speed Sensor (OSS) signal faults to disable various On-Board Diagnostic (OBD) monitors without illuminating the MIL.
Dealers are to reprogram the PCM to the latest calibration using IDS release 90.01 or higher. This service must be performed on all affected vehicles at no charge to the vehicle owner.
SERVICE PROCEDURE
Important Information for Module Programming
NOTE:
When programming or reprogramming a module, use the following basic checks to ensure programming completes without errors.
^ Make sure the 12V battery is fully charged before carrying out the programming steps and connect IDS/scan tool to a power source.
^ Inspect Vehicle Communication Module (VCM) and cables for any damage. Make sure scan tool connections are not interrupted during programming.
^ A hardwired connection is strongly recommended.
^ Turn off all unnecessary accessories (radio, heated/cooled seats, headlamps, interior lamps, HVAC system, etc.) and close doors.
^ Disconnect/depower any aftermarket accessories (remote start, alarm, power inverter, CB radio, etc.).
^ Follow all scan tool on-screen instructions carefully.
^ Disable IDS/scan tool sleep mode, screensaver, hibernation modes.
^ Create all sessions Key On Engine Off (KOEO). Starting the vehicle before creating a session will cause errors within the programming inhale process.
Module Reprogramming
NOTE:
Reprogram appropriate vehicle modules before performing diagnostics and clear all Diagnostic Trouble Codes (DTCs) after programming. For DTCs generated after reprogramming, follow normal diagnostic service procedures.
1.Connect a battery charger to the 12V battery.
2.Reprogram the PCM using IDS release 90.01 or higher.
NOTE:
Calibration files may also be obtained at the website.
NOTE:
Follow the IDS on-screen instructions to complete the reprogramming procedure.
3.Disconnect the battery charger from the 12V battery, once reprogramming has completed.
Recovering a module when programming has resulted in a blank module: NEVER DELETE THE ORIGINAL SESSION!
a.Obtain the original IDS that was used when the programming error occurred during Module Reprogramming (MR) or Programmable Module Installation (PMI).
b.Disconnect the VCM from the Data Link Connector (DLC) and the IDS.
c.Reconnect the VCM to IDS and then connect to the DLC. Once reconnected, the VCM icon should appear in the corner of the IDS screen. If it does not, troubleshoot the IDS to VCM connection.
d.Locate the ORIGINAL vehicle session when programming failed. This should be the last session used in most cases. If not, use the session created on the date that the programming failed.
NOTE:
If the original session is not listed in the previous session list, click the ''Recycle Bin'' icon at the lower right of the previous session screen. This loads any deleted sessions and allows you to look through them. Double-click the session to restore it.
e.Once the session is loaded, the failed process should resume automatically.
f.If programming does not resume automatically, proceed to the Module Programming menu and select the previously attempted process, PMI or MR.
g.Follow all on-screen prompts/instructions.
h.The last screen on the IDS may list additional steps required to complete the programming process. Make sure all applicable steps listed on the screen are followed in order.
Mar 9, 2019 at 5:56 AM
