I am having trouble diagnosing a p1283 code on my vehicle listed above. I have replaced both upstream sensors.There no obvious exhaust leaks I have done all the diagnosing as described in the factory service manual (FSM) so there is no shorted or open wires in the harness.Also I have done the accelerator pedal position re-learn, throttle valve closed position re-learn, idle air volume re-learn and the air fuel ratio reset that are all listed in the FSM. After all this I am still getting the code. This is after swapping in a used engine that had approximately 67,000 miles on it. I replaced all the gaskets from the heads up and installed new primary catalytic converters.
Apr 25, 2020 at 1:08 PM
