I'm getting a P1151 code, which is for Bank 2 sensor 1 O2 sensor. Although I am not getting any additional codes, my scanner is telling me that I have failure in:
# 26 Initial tank vacuum and maximum limit in H20
# 2A Phase 4 Vapor generation maximum change in pressure and max threshold in H20
# 2B Phase 4 Vapor generation maximum absolute pressure rise and max threshold in H20
I'm concerned THIS is why I'm getting the P1151 code, but I don't know how to correct these other failures. I have already replaced all 6 injectors to get rid of cylinder misfire codes, as well as plugs, plug wires, coil pack and PCV. I have cleaned MAF sensor and throttle body, but I'm getting the same rough idle/running like I did with the initial misfires.
Thanks for the help.
Aug 3, 2020 at 12:51 PM
