Codes P1101 and P0420, after replacing the MAF sensor?
2014 CHEVROLET CRUZE
86,300 MILES • 1.4L • 4 CYL • 4WD • AUTOMATIC
JBAHUN1
  • 11 POSTS
I'm getting these codes after I have replaced the MAF sensor. I haven't replaced the 02 sensors or catalytic converter since I got the car in 2014. If you do recommend a new catalytic converter, can you please share a link to which one would work best?
Jan 7, 2025 at 8:01 PM
If you did not have these codes before I would replace the MAF sensor which sounds like you have a defective part. Can I ask which brand it is?
Code P1101 - Intake Air Flow System Performance
Code P0420 - Catalyst System Efficiency Below Threshold (Bank 1)
Here is the correct way to change out the sensor so we can be on the same page. Also, if the turbo is having an issue, it will cause an internal vacuum leak. FYI. Clear the codes once the repair is done and please get back to me. Check out the images (below).
Jan 9, 2025 at 11:08 AM
JBAHUN1
  • 11 POSTS
Mass Airflow Sensor for: Chevy Cruze Limited Sonic Trax for: Buick Encore Verano 1.4L 1.6L 1.8L 2.0L 2.4L 2012-2019 Replacement OE# 245-1314 12671624 0280218419 0280218273 13432262 5S13839
Replaced MAF sensor with link above, it seems to be working. I then cleared these codes from my OBII scanner and now they're gone and there is no check engine light. I was told now i need to make some drive cycles so that the monitors can be set to Ready as I failed my emissions test here in TX a few days ago when i disconnected the negative battery then got it inspected which was ultimately a fail. I was advised to use some Cataclean solution when my gas tank is 1/4. Thanks for the help.
Jan 9, 2025 at 12:45 PM
Okay, it sounds like you are on the right track. Do the drive cycles, if you have a scanner, it might have the monitor status so you can see when the monitors have been completed. Have a good weekend, please let me know. Also, if you drive the car easy the cat can do its job better FYI.
Jan 10, 2025 at 9:26 AM
JBAHUN1
  • 11 POSTS
Engine light came back on when driving on freeway yesterday (P1101 - Manufacture other). When I clear this code it goes away however. After I have cleared the code the drive cycles on my OBII read:
Mill Status: OFF
Misfire Monitor: OK
Fuel System Mon: INC
Comp.Component: OK
Catalyst Mon: INC
HTD Catalyst: N/A
EVAP System Mon: N/A
Sec Air System: N/A
A/C Refrig Mon: N/A
Oxygen Sens Mon: INC
Oxygen sens Htr: INC
EGR System: INC
Also I have not yet put the cataclean solution in yet as im at half a tank of gas that's left.
Jan 12, 2025 at 7:01 AM
I would check the air intake boot and connection to the throttle body, you can get this code if there is a leak between the MAF and the throttle body, also check the air filter as well. Let me know if you find something that might cause it so I can help confirm the issue.
Jan 13, 2025 at 1:01 PM
JBAHUN1
  • 11 POSTS
I didn't see any leaks, connection was tight not lose at all. Sprayed some Johnsen's 4721 Mass Air Flow Sensor Cleaner - 10 oz cleaner in the air filter box. Will be replacing air filter tomorrow as I never have on this car. It was super dirty. Will try this new filter and see what the cleaner does in next few days.
Jan 13, 2025 at 1:52 PM
JBAHUN1
  • 11 POSTS
should i maybe take a look and clean the throttle body?
Jan 13, 2025 at 2:18 PM
Yep, that is a good idea, here is a guide to help you:
Please go over this guide and get back to us. I think the air filter might fix it.
Jan 14, 2025 at 10:08 AM
JBAHUN1
  • 11 POSTS
I changed air filter, MAF sensor and cleaned out the air filter compartment and doesn't seem to have fix. The engine light came on again. I'm unsure of where/how to get to the throttle body on my car and each video i seem to locate doesn't explain it very well. would you have a guide, or would you be able to tell from these pics?
Jan 15, 2025 at 11:53 AM
JBAHUN1
  • 11 POSTS
I think it's connected to the hose in the center.
Jan 15, 2025 at 12:46 PM
New air filter, MAF sensor with no leaks, I would start looking at the turbo, when they wear out, they can leak internally which can cause these codes as well, can you confirm you are still getting the same codes? Also, does the turbo seem to work good before all this started? Thanks for the images, they help.
Jan 16, 2025 at 9:14 AM
JBAHUN1
  • 11 POSTS
These both came on the other night When I was driving on the highway for a bit. I've noticed when changing the MAF sensor i seem to have a little more power feels like. I really didn't have any issues with the turbo when I was aware if these codes. I do remember when driving on the highway before getting my oil changed 1-2-25 that my engine light was constantly appearing and when i mashed the throttle all the way down the RPM would get to the max range and the speed of the car was fine could get it up to 95.
I haven't tried using the Cataclean yet as I'm at half a tank of gas left. Want to get down to 1/4 before trying that. I spoke last night to a local mechanic mom and pop shop and maybe taking it to them next to see what they say but I'm trying to do everything i can to clean codes to pass emissions before shilling out more money.
Jan 16, 2025 at 9:20 AM
Good idea, did you clear the codes after the repairs? If so, are they the same codes? I would clear the codes and drive it easy to see what happens.
Jan 17, 2025 at 11:33 AM
JBAHUN1
  • 11 POSTS
Yes cleared them 2 days ago they both came back, and engine light returned so that is current status of now. Waiting for my gas tank to get to 1/4 so i can try that Cataclean and then re-fill gas tank and drive like a madman and see if that does anything to these codes.
Jan 17, 2025 at 11:40 AM
Okay, let me know how it goes.
Jan 17, 2025 at 12:10 PM
JBAHUN1
  • 11 POSTS
will do. any other recommendations or have you see these issues cured in the past with chevy cruzes?
Jan 17, 2025 at 12:15 PM
Not really, just change the oil and filter with the air filter, they are pretty good cars.
Jan 18, 2025 at 10:23 AM
JBAHUN1
  • 11 POSTS
cataclean seemed to work for now. engine light is no longer appearing, didn't clear any codes either. I had a local mechanic shop reach out to me a few weeks ago but wanted to try this first before going there or going to get another emissions test. Do you think it would pass an emissions test now? I still have P1101 code though.
Feb 3, 2025 at 4:47 PM
I don't think it will pass with the P1101 code. I would make sure the air filter is clean, and you don't have any leaks between the MAF and the throttle body. Also, recheck the electrical connector to the MAF sensor and see if any pins are dirty or corroded. I have also seen that if the engine has too much blow by it can cause this code as well.
Feb 4, 2025 at 9:04 AM
JBAHUN1
  • 11 POSTS
cleaned throttle body and replaced value cover gasket. still getting p1101 and p0171. misfires n/a on htd catalyst, a/c refrig mon, sec air system on my code reader. engine light sometimes on but then goes off it varies and is inconsistent
Dec 14, 2025 at 7:59 PM
I would try a Delphi MAF sensor. Sometimes the reading can be off in aftermarket sensor which will cause both of these codes. Also, you might want to remove the inlet/outlet of the turbo to see if the main shaft has excessive play, this will fool the MAF sensor and cause mixture issues like you are having. Please let me know, Ken
Dec 15, 2025 at 12:04 PM
