Hello again, recently my RSX has had the engine light illuminating. After using a diagnostic, I have discovered that it has stored the diagnostic code P1078.
I have tested the wiring on the IMRC except for internal resistance (Due to the awkward position of the sensor). I have visually inspected the vacuum tubing for cracks but have not discovered anything (unless there are recommendations to find hairline cracks). I could not check its ability to hold vacuum as I do not have a vacuum pump/gauge and they are rather expensive.
I also removed the IMRC actuator a while back, cleaned both it and its chamber, and put the valve back. I am beginning to think the valve was positioned incorrectly however, as I did not have a vacuum pump to rotate it to the correct position and rotated it by hand instead.
I have reset the ECM several times to see if the code returns and it normally does. On the last reset, I took the car for a drive, and waited for the DTC to return. After parking, shutting the car off and later returning and starting it, the DTC was triggered. I have attached the information below from the diagnostic if it may help to understand if the issue is a result of air flow.
Aug 31, 2018 at 11:18 AM
