P1000 code
2003 LINCOLN LS
100,000 MILES • 0.5L • V8 • 2WD • AUTOMATIC
NNK76
Car overheats and has no acceleration. It will only idle in gear.
Oct 17, 2018 at 11:28 AM
Good afternoon.
The P1000 possibilities are listed below for you to view.
This has nothing to do with your issue.
You need to find out why it is overheating. There are many possibilities for this and it could be connected to not accelerating as well.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
P1000
P1000
Descriptor
Obd (On Board Diagnostic) System Readiness Test Not Complete
Probable Causes
Battery or Power Control Module (PCM) Recently Disconnected
On-Board Diagnostics (OBD) Monitor Malfunction Occurred Before Completion of OBD Drive Cycle
Power Take Off (PTO) Circuit Shorted to Voltage Power or B+ or PTO On During Testing
Powertrain Control Module (PCM) DTC's Have Recently Been Cleared with a Scan Tool
Vehicle is New From Factory
Oct 17, 2018 at 12:20 PM
