Replaced 3rd gear sensor and 3.1 quarts of transmission fluid. I did not clear code with scanner or disconnect battery due to losing I/M readiness (for smog check).Just kept driving and hoping for ECM/PCM to clear the code with no success for 2 days. What should I do next? My registration/smog check is due in 3 days. How long will ECM take to clear the code, or I'll have to manually clear it? The car/transmission runs fine with no shifting problem other than that. I forgot to add that, the new and the old sensors both behave the same. Replacing the sensor didn't help. I bet the old sensor was good. Also, the number of DTC codes displayed in the scanner is 1(1 in red color) which I've never seen before. I removed the new switch and tested for resistance between the single pin and the body ground and I saw an open, I got the same result with the old switch as well. Is this switch a NC(normal close) or NO(normal open)?I've seen some online with 0.5Ohm when measured. If it's NC, then both switches are bad.I also tested the single wire plug lead with the engine ON/OFF.I got 5V with engine on and nothing with engine off. Does this narrow down to the switch itself?I can't think of any other components that can cause this P0845 code. Also, no visual 'check engine' light displayed on dashboard. I can only find out with an OBD2 scanner. Please help.
Feb 22, 2023 at 9:12 AM
