Codes P0746 and P0766?
2009 TOYOTA RAV4
120,000 MILES • 2.4L • 4 CYL • 4WD • AUTOMATIC
OWAIS AHMAD
My transmission is slipping after like a mile of driving! If I wait for half hour so it’s can go another bit and slip again! Got p0746 and p0766 and I checked the transmission oil it’s black! Please advise how I could fix this! Thanks
Jul 27, 2025 at 1:06 AM
STEVE W.
  • 15,113 POSTS
The two codes are transmission related 746 is the pressure regulating solenoid A while the 766 is shift solenoid D performance. From your description the pressure solenoid isn't operating properly and that is causing the transmission to slip and burn the fluid and likely it has damaged the clutches and steels from the excessive heat that generates. That is also why the fluid is black. At this point about the only solution would be to either rebuild or replace the transmission. Changing the fluid and replacing the solenoids isn't going to help at this point because of the physical damage in the transmission. The parts to rebuild it are not that expensive but there are a few special tools that are required and those are expensive.
Jul 27, 2025 at 10:04 AM
