When driving first and second gear are fine no check engine light. When it’s time to shift to third the clutch is engaged (automatic transmission) but will not shift in to third. Rpm's go up but does not shift. Then goes down to second gear and check engine light comes on. Codes P0733 and p1790 p0700 and stays in limp mode. Is this an electrical or mechanical issues? How can i fix this? Thank you in advance
Jul 22, 2019 at 4:21 AM
