Code P0732, second gear incorrect ratio, where is the transmission module located?
2014 HYUNDAI SANTA FE
149,130 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
ANDRIN ATEM
  • 393 POSTS
Please can you kindly provide me with the exact location of the transmission module and the wiring for a diagram containing ground signal.
Any information that can be helpful to solve this problem. Hi Ken, please I noticed I would just need the diagram and signals of this solenoid valve connector.
5XYZT3LB6EG145851
Dec 29, 2024 at 1:48 PM
ANDRIN ATEM
  • 393 POSTS
Dec 29, 2024 at 11:15 PM
Hi Andrin,
Here is the location for the transmission control module and the wiring diagrams for it, but I can tell you I have seen a weak input shaft sensor cause this problem as well. Here is the location for the sensor as well. Clear the codes once the sensor or TCM is replaced. Check out the images (below). Please let us know what happens.
Dec 30, 2024 at 10:50 AM
ANDRIN ATEM
  • 393 POSTS
Thank you, Ken, i have read the updates and the diagrams. May i have measurements for testing the out speed sensor and input sensors? Also, if possible, to have the pinout of for the solenoid valve connector Pinout signals?
Dec 30, 2024 at 6:47 PM
This is what they say:
For most Hyundai models, the resistance of both sensors should be within the range of 500 to 1,000 ohms.
This sounds too high to me btw. Which solenoid valve are you talking about?
Dec 31, 2024 at 11:33 AM
ANDRIN ATEM
  • 393 POSTS
Transmission Output speed sensor and the input speed sensor, which is behind the valve body inside the gearbox.
Dec 31, 2024 at 12:36 PM
ANDRIN ATEM
  • 393 POSTS
Also if I can get the pin out for the fuse box connector, and the power and ground for the TCM/ECM. For the ohms resistance, I will also double check. Thank you.
Dec 31, 2024 at 12:38 PM
There is no TCM only the PCM, here are the pinouts and the wiring diagrams I have provided above. Check out the images (below). Let us know what you find.
Jan 1, 2025 at 10:31 AM
ANDRIN ATEM
  • 393 POSTS
Thank Ken, what I realized, the output speed sensor is reading higher than the specified reading from the repair service manual. So I ordered a new sensors for replacement.
The informations you provided was vital and I could not figure it out without the informations provided to me.
Thanks very much.
Jan 7, 2025 at 2:13 PM
You are welcome, please use 2CarPros anytime we are here to help.
Jan 9, 2025 at 10:26 AM
ANDRIN ATEM
  • 393 POSTS
Please, i am still on this Hyundai as this has been a tough one for me, i have even replace a new transmission and yet the transmission is stock on 4th gear. Please may i have the network communication diagram for this transmission, also the grounding?
Feb 6, 2025 at 7:50 AM
ANDRIN ATEM
  • 393 POSTS
But what amazes me is that this hall affect output and input speed sensor has no resistance. Is the actually an information of a resistance for this sensors?
Feb 6, 2025 at 7:52 AM
P0732 - Gear 2 Incorrect Ratio
Hall Effect sensors typically do not have measurable resistance across their terminals when tested with a standard multimeter. Here is the CAN network diagrams as requested.
Feb 6, 2025 at 9:20 AM
ANDRIN ATEM
  • 393 POSTS
Thank you.
Feb 6, 2025 at 10:42 AM
ANDRIN ATEM
  • 393 POSTS
Thank you once more Ken, please can i get the ground location wires in the engine compactment?
Feb 7, 2025 at 6:49 AM
Sure, here are the engine compartment grounds. Check out the images (below). Let us know what you find.
Feb 7, 2025 at 6:15 PM
ANDRIN ATEM
  • 393 POSTS
Hi Ken, please I would like to truly verify if this Hyundai has a transmission module or it’s the same as the PCM or ECU.
Feb 12, 2025 at 11:54 AM
ANDRIN ATEM
  • 393 POSTS
And if it has a transmission module, can you help me get its exact position?
Feb 12, 2025 at 11:55 AM
There is no TCM only a PCM that runs the transmission.
Feb 13, 2025 at 9:11 AM
ANDRIN ATEM
  • 393 POSTS
I have noticed that signals that leaves the TCM to the gear switch range senso are not consistent with what the factory diagram prescribes. So, I wonder if we might a wrong ecu on this car. Any ideas on what the correct Tec or ecu goes for this 2.4 gdi sports?
Feb 13, 2025 at 3:52 PM
Is this a euro car?
Feb 14, 2025 at 10:37 AM
ANDRIN ATEM
  • 393 POSTS
No, it’s from US
Feb 14, 2025 at 11:39 AM
Yep here is the info,
Non-SCC (Smart Cruise Control): ECU part number 211012GK02QQH
SCC-equipped: ECU part number 211012GK02QQH
Feb 15, 2025 at 9:50 AM
