Code P0725?
2002 DODGE DAKOTA
149,246 MILES • 4.7L • V8 • 4WD • AUTOMATIC
EARL91
  • 89 POSTS
I have replaced the crank sensor and speed sensor. Put a new fuel sending unit in. So, the fuel gauge sometimes works and when it does the truck will start and run but stalls after a while. I cleaned the cluster and checked all relays. Everything is good on that end. Idk what it could be.
Jun 26, 2023 at 12:02 PM
It sounds like the PCM is bad, I would send it out for testing here is the location so you can check it out, you can get a preprogrammed unit by searching Google or Ebay. here is more information:
The P0725 error code in an automobile diagnostic reading represents an issue with the "Engine Speed Input Circuit".
Check out the images (below). Please let us know how it goes.
Jun 26, 2023 at 6:48 PM
EARL91
  • 89 POSTS
Any way you could send me wiring diagram for speed sensor.
Jun 27, 2023 at 5:30 AM
MATHGEN
  • 128 POSTS
Here is the schematic and connector pinout for the CKP sensor. Let us know if you need more assistance.
Jun 27, 2023 at 5:48 AM
EARL91
  • 89 POSTS
i see were the wires clip onto the PCM were broken causing a bad connection. so, i have ordered a new one. will keep ya'll updated.
Jul 13, 2023 at 1:39 PM
Please do, have a great day!
Jul 14, 2023 at 8:53 AM
