Code P0722, where is the output shaft speed sensor located?
2013 MAZDA 3
140,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
CRYSTAL1983
MEMBER
1 POST
FOLLOW
I got the error code P0722, says to replace the output shaft speed sensor. I cannot find where that is located on this car. Please help me, thanks.
Jul 6, 2023 at 12:25 PM
MATHGEN
CERTIFIED EXPERT
Hello. I came across a TSB for the P0722 code. It may or may not apply to your vehicle. Here is the note from the TSB with the VIN range of vehicles it applies to.
2012-2013 Mazda3 automatic transaxle vehicles with VINs between JM1BL******732088 - 814225 (produced up to March 26, 2013)
According to pinpoint tests I have come across, you would need to have the TCM updated first. If the problem persists, then it is directed to replace the main control valve body.
