Hello, it looks like the Input Shaft (Main shaft) Speed sensor is a hall effect sensor with 3 wires, the P0717 is a circuit code and the P0718 is an Intermittent Failure code, so this is probably a wiring issue if you have already replaced the sensor, but at the sensor there should be 3 wires, the first is a Yellow wire with a Blue stripe. If you unplug the sensor, then with the key On, that wire should read 5 volts. I'll post a wiring diagram as well, but that's the sensors 5volt reference feed. Measure with a multimeter set on DC volts, with the red lead on the Yellow/Blue wire and the black lead on battery negative. It should read 5 volts.
There is an entire flow chart you can follow for this code Ill post that as well, but the 3rd wire which is Green/Yellow should be the sensors Ground that runs through the PCM.
So, you can technically check for 5volts using pin 1 and pin 3 of the sensor's connector, should still read 5 volts.
Hopefully you are comfortable with multimeter testing, Honda always has a flow chart of voltage and resistance testing to do per each code.
Apr 6, 2024 at 2:53 PM
