Code P0715?
1996 HONDA ACCORD
187,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
BIGMEECH41
The car is throwing code P0715 for the turbine/input shaft sensor. I want to change both the input and output but all the pictures I have seen do not help me to find the locations. Could you please provide pictures and directions to where they are so I can change them?
Feb 8, 2023 at 3:31 PM
AL514
  • 5,462 POSTS
Hello, Honda calls the Input shaft speed sensor a Main shaft speed sensor and the Output speed sensor which would set a P0720 is called a Countershaft speed sensor, Ill post diagrams of where they are. They also have a vehicle speed sensor, which they have a ratio between the main shaft speed sensor and the vehicle speed sensor that is calculated and if it's within a specific range it will set the P0715. Hopefully I have that all correct, so I assume your speedometer is working correctly? You are just getting a check engine light and the p0715?
I'm posting the p0720 just so you can see it considered the output shaft speed sensor.
Feb 9, 2023 at 10:16 AM
CORYV
  • 7 POSTS
My speedometer hasn't been working could it be that VSS is related to the p0715 code as well?
Oct 22, 2024 at 1:59 PM
AL514
  • 5,462 POSTS
This post is from Feb 2023, You are still dealing with a P0715?
Oct 23, 2024 at 3:53 PM
CORYV
  • 7 POSTS
I am, i just commented on your post yesterday.
Oct 23, 2024 at 4:47 PM
AL514
  • 5,462 POSTS
Yes I saw the posting, just wondering if the code came back or if it has been like this since Feb 2023 still.
Oct 25, 2024 at 6:53 AM
