Hello and welcome to 2CarPros. Here is a circuit description so you can see what is controlled on the 5 volt reference:
Collision
62
2008 Chevrolet Cobalt
L4-2.2L
P0651
Vehicle ALL Diagnostic Trouble Codes ( DTC ) Testing and Inspection P Code Charts P0651
P0651
DTC P0641 or P0651
Diagnostic Instructions
* Perform the Diagnostic System Check - Vehicle prior to using this diagnostic procedure. See: Vehicle > Initial Inspection and Diagnostic Overview
* Review Strategy Based Diagnosis for an overview of the diagnostic approach.
* Diagnostic Procedure Instructions provides an overview of each of the diagnostic category.
DTC Descriptors
DTC P0641
- 5-Volt Reference 1 Circuit
DTC P0651
- 5-Volt Reference 2 Circuit
Diagnostic Fault Information
Open In New TabZoom/Print
Circuit/System Description
The engine control module (ECM) has 2 internal 5-volt reference busses called 5-volt reference 1 and 5-volt reference 2. Each reference buss provides 5-volt reference circuits for more than one sensor. A fault condition on one 5-volt reference circuit will affect the other 5-volt reference circuits connected to that reference buss. The ECM monitors the voltage on the 5-volt reference buss.
The 5-volt reference 1 buss provides 5 volts to the following sensors:
* The manifold absolute pressure (MAP) sensor
* The fuel tank pressure (FTP) sensor
* The air conditioning (A/C) refrigerant pressure sensor
* The accelerator pedal position (APP) sensor 2
* The exhaust camshaft position (CMP) sensor
* The intake CMP sensor
The 5-volt reference 2 buss provides 5 volts to the following sensors:
* The APP sensor 1
* The throttle position (TP) sensor 1 and 2
* The crankshaft position (CKP) sensor
* The secondary air injection (AIR) solenoid
At the throttle body, back probe the grey wire on the connector with key on engine off.since the 5 volts is missing, unplug the connector with the probe still attached. If the 5 volts comes back on the throttle is bad. If no 5 volts then start unplugging every component on bus 2. The APP is the accelerator pedal so unplug it. If the 5 volts comes back on then the APP is bad and if not unplug every component until you get 5 volts back. Let us know what the test results are.
You can also work backwards and unplug everything in that circuit and plug one item at a time until you lose the 5 volts to isolate the problem. If you have any questions, don't hesitate to ask.
Sep 13, 2019 at 9:36 PM
