Code P0607 occurs after engine startup?
2010 DAIHATSU HYJET
254,000 MILES • 1.6L • 3 CYL • 2WD • AUTOMATIC
SHINAZ
Engine control unit malfunction fault occurs after engine startup, sometimes it runs good for around 2-3 hours and sometimes after startup fault occurs and when the fault is present RPMs starts fluctuating and accelerator pedal stop responding. I have switched ecu to another vehicle and it runs fine.
Mar 4, 2025 at 12:07 PM
So this can be one of the ignition coils, fuel injectors, or oxygen sensors that has shorted out
The P0607 code refers to an ECM/PCM Internal Circuit Malfunction.
I would clear the codes and then without starting the engine turn the key on and then run the codes again. If the code comes up start unplugging the ignition coils and repeat until the code ceases, you have found the problem, here is how to test the fuel injectors manually.
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Did you run the codes to see if there were any stored? This guide can help:
Please upload pictures or videos in your response of any problems so we can see what to help you with.
Mar 5, 2025 at 9:58 AM
SHINAZ
Engine control unit malfunction fault occurs after engine startup , some times it runs good for around 2-3hrs and sometimes after startup fault occurs and when the fault is present Rpm start fluctuating and accelerator pedal stop responding. I have switched ecu to another vehicle and it runs fine
Mar 5, 2025 at 4:35 PM (Merged)
I would try unplugging the primary oxygen sensors to see if that makes a difference, I have seen the heater element inside the sensor short to ground and cause this issue.
Mar 5, 2025 at 4:39 PM
