The trouble codes P0581 and P0593 that you're seeing on your 2008 Dodge Caliber are indeed related to the cruise control system:
P0581: Cruise Control Multi-Function Input “A” Circuit High
P0593: Cruise Control Multi-Function Input “B” Circuit High
It could be the ignition system is back feeding into the PCM and causing these codes as a glitch. I would do a full tune up with ignition coils and then clear the codes to see what happens. Here are the instructions on how to do the job.
Install each spark plug to the cylinder head. Tighten spark plugs to 27 Nm (20 ft. lbs.).
Aug 19, 2024 at 10:31 AM
