Is this the one on front of the head, or the one in back or the one by filter housing? Replaced the one on front of head made no difference.
Apr 12, 2023 at 3:24 PM
CERTIFIED EXPERT
The code P0522 indicates that there is a problem with the engine oil pressure sensor or the oil pressure sensor circuit. I would start by checking the connection at the sensor and then inspect the wiring harness for damage. Here is the location of the pressure sensor. Check out the images (below). Please let us know what happens.
Image (Click to enlarge)
Apr 13, 2023 at 10:48 AM
BHAMDOC1973
MEMBER
I checked connection on all 3 sensors, 2 on head and one by oil filter.
Apr 13, 2023 at 10:51 AM
BHAMDOC1973
MEMBER
Can you help with it or no?
Apr 14, 2023 at 12:42 PM
CERTIFIED EXPERT
You asked for the oil pressure sensor the post had a typo, I apologize.
Apr 15, 2023 at 10:08 AM
BHAMDOC1973
MEMBER
I never said anything about the starter. I said why are you talking about the starter in your answer above? I only asked about the oil pressure sensor.
Apr 15, 2023 at 10:12 AM
CERTIFIED EXPERT
It could be the engine has low oil pressure; I would use a manual gauge to check it. You can rent one from the auto part store for cheap if you don't have one. Please let me know what the reading is.
Apr 17, 2023 at 9:35 AM
BHAMDOC1973
MEMBER
I did that and it was within range and no funny noises from motor and it's so smooth. Just strange.
Apr 17, 2023 at 9:38 AM
CERTIFIED EXPERT
What pressures were you getting?
Apr 18, 2023 at 8:51 AM
BHAMDOC1973
MEMBER
Got it fixed. Went and cleaned the connection by the oil filter again with electric spray, and when it clipped it did so differently, so all good.
