I have a high idle rpm's and lean condition on both banks. the pids for the short fuel trim are positive 25 and long term fuel trim 20 at idle. they decrease when under load.my question is i put smoke through the intake hose and the PCV valve the ones with a diaphragm was leaking smoke. are they suppose to leak smoke? i read they do cause a lean code on both banks and rough idle, like i get when ever i reset the code until the pids adapt. Or could it be a vacuum leak?
Dec 26, 2019 at 4:32 PM
