After cleaning Throttle Control Body (did not open butterfly with my hands - used the accelerator pedal to open it and then clean it - I used Throttle Body cleaner spray for it) started getting this code. Got annoyed, and did it again, this time taking it out and cleaning it - also disconnected the MAP sensor from it and cleaned it with Electronic cleaner spray; also took EGR out and cleaned - cleaned MAF sensor to, using MAF sensor cleaner spray. To make it better, not just the P0507 shows up, but now I am getting a P1129 - tried to do the "Idle relearn", several times, but did not seems to work - cleared the code with the scanner and also disconnecting the battery - I will change oil next week since those several tries of relearn running the RPM 3K for "x" amount of tine, probably burned the oil - I will change it before trying again - I was forgetting, all started with the car trying to overheat, and i found out that the radiator had some damage bellow so, I changed it. I did the purge 2 times, and still kind of trying to overheat - just found out that i have some problem with the small reservoir since i listened it making some sound of air escaping/leaking from it - So, any help for my adventures?
Nov 1, 2024 at 2:00 PM
