Code P0302 with VSA activation indicator lamp and Malfunction indicator lamp turned on?
2009 HONDA ACCORD
159,500 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
XJSHEN
  • 245 POSTS
On my car listed above VSA lamp with triangle VSA activation indicator lamp and Malfunction indicator lamp turned on at dashboard. Two p0302 codes with cylinder 2 misfire detected on IBDII detector.
symptoms:
During acceleration, the car hesitates if RPM increased to 60 mph. was car could not accelerate more than 60 mph, and with hesitate.
I ordered a VSA switch. Now even at low mph car hesitates.
I replaced cylinder 2 spark plug, replaced engine oil filter.
Thanks for your instructions and helps!
Sep 26, 2024 at 4:25 PM
XJSHEN
  • 245 POSTS
On IBDII scanner this value may be problematic: ST FTRM12 (%) -7 ; A minus value on my car? (Honda Accord 2009)
Sep 27, 2024 at 2:32 AM
XJSHEN
  • 245 POSTS
Here is record copy.
Sep 27, 2024 at 3:24 AM
XJSHEN
  • 245 POSTS
it was my fault the p0502 was wrong, the error code was p0302 code.
Sep 27, 2024 at 8:01 AM
I would worry about the P0302 code first, which is a misfire code for cylinder number 2. remove the spark plug and replace it along with the ignition coil which should fix it.
Here is a guide to help with more information:
https://www.2carpros.com/articles/engine-misfires-or-runs-rough
This guide should help as well:
https://www.2carpros.com/articles/how-to-change-spark-plugs
Clear the codes once the repair is completed. Check out the images (below). Please upload pictures or videos in your response of any problems so we can see what to help you with.
Sep 27, 2024 at 12:00 PM
XJSHEN
  • 245 POSTS
On my 2009 Honda Accord VSA lamp with triangle VSA activation indicator lamp and Malfunction indicator lamp turned on at dashboard. Two p0302 codes with cylinder 2 misfire detected on IBDII detector.
On IBDII scanner : ST FTRM12 (%) -7 ; A minus value on my car (Honda accord 2009)
Symptoms:
During acceleration, the car hesitates if RPM increased to 60 mph. Was car could not accelerate more than 60 mph, and with hesitate.
Sep 27, 2024 at 1:14 PM (Merged)
a negative fuel trim indicates that the engine control module (ECM) is reducing the amount of fuel being injected because the engine is running rich. What did the number #2 spark plug look like was it black? If so, you could have low compression, or the fuel injector is stuck open. Use this guide to help check the compression:
Sep 28, 2024 at 10:24 AM
XJSHEN
  • 245 POSTS
Hi Ken,
Thank you so much for your precious instruction. I tested VSA switch was bad, and No. 2 spark switches also did not have resistances. And ordered them through eBay, but first round shaping from sellers who deal with Japanese parts, was all sent wrong sized parts, and did not replace with normal parts, and spark plugs included two of four defected plugs without resistances. I had to order new from different seller that took me 15 days to fix my car. Yesterday I eventually cleared the code and run drive cycles, and my car is running normal now. Again thanks!
Oct 21, 2024 at 7:31 AM
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
Oct 21, 2024 at 9:51 AM
