P0500 Vehicle speed sensor
2008 FORD F-350
125,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
JONES57
  • 4 POSTS
Have P0500 code, no speedometer. check engine light Abs light and about every warning light on Problem started suddenly Changed out speed sensor on rear differential and had no change Where do I go from here
Aug 10, 2025 at 1:07 PM
I think you replaced the wrong sensor, here is where the manual says the sensor it which is on the upper side of the transmission adapter for the transfer case.
P0500 code Vehicle Speed Sensor (VSS) - No Signal
This is what it looks like and how to change it out. Be sure to clear the codes once completed. Check out the images (below). Let us know how it goes
Aug 11, 2025 at 10:42 AM
JONES57
  • 4 POSTS
thank you will try this next
Aug 11, 2025 at 12:22 PM
Sounds good that should fix it. Please let me know :)
Aug 11, 2025 at 1:14 PM
JONES57
  • 4 POSTS
Hi Ken the sensors I can get locally are almost 4 times the price I can get it from Rock Auto
So part will not be here until Friday Will Let you know then
Aug 11, 2025 at 1:19 PM
Sounds good, I like rock auto
Aug 11, 2025 at 1:30 PM
